I will try to explain in detail-
My equipment - Hayward Varible Speed Pump and a Aqua-Rite Salt water Generator.
my pump is programmed to run 24 hours a day. The lowest speed in that 24 hour period is 2300. Today, I came home and checked the salt level on the aqua rite- I found it with the NO FLOW on and the generating light off. I cut the box and pump off. Started it back up - Same result. So, I pressed the quick clean button (which brings the pump to fuill speed 3420) Once it was a full speed the low flow light flashed and went off- The generating light came on. All was well-
We were out of town for 3 days. I left the pool clean and came back to green pool. The box once again shows no flow- I pressed the quick clean and the light went off.
I went to my pool installer and had the water tested and got all the chemicals to get everything back in shape. They seem to think everything is fine-- They mentioned the board or Flow Sensor..... They are slammed and I really need some advice,
What do I need to do? The pool is 3 years old. The salt cell has never been cleaned. I backwash often..... The pool is back cloudy.....but the water is flowing properly. Help!!
