OK now I see how you came up with that number. As @IceShadow said, you should check FC after your last addition to get a real baseline. Keep at it! I thought my 32 gallons over 5 days was a lot, but yours must be way over that!
Alkalinity won’t rise without additions of chems. pH will. Add muriatic acid to bring it back down to 7.4 or 7.6 when it gets to 8.0. Over time the muriatic acid will reduce the TA as well.
Sometimes a static electric charge can build up on the R-0009 dropper bottle tip, causing the drops to be smaller than usual and making the test read higher than actual. You can prevent this by wipping the tip of the dropper bottle with a damp cloth or tissue before you start and after each drop.
