Hey there,
Could you please post what your levels are now..
FC
CC
PH
TA
CH
CYA
nothing magical about the levels just most people have never heard it because the pool companies continue to use methods from the 1970's.. We now have another 50 years of knowledge but they refuse to look at it and change because they would lose money...
So you would go off the levels for your vinyl pool.. You would want at least 30 CYA and that would have your FC always above 2FC and you want to target 4 to 6FC everyday.. You never want to get below 2FC as you can have algae start to grow...
Recommended Levels
FC/CYA Levels
So the Pool lab 1.0 can check FC up to 8 ppm or 8 mg/l so you can do the daily checks no problem.. If you needed to SLAM to get rid of an algae bloom (green pool) see below...
Just found this, you can dilute your FC to get a higher amount..
PoolLab.org - official website | Water-i.d. GmbH This would allow you to test up to 50 mg/l so you would be able to do a SLAM with the Pool Lab 1.0
How do I dilute correctly?
If the result is "OR" or water values outside the measuring range of the parameter on the PoolLab are expected, the water sample must be diluted (does not work with pH!)
Dilution is usually done with distilled water. For chlorine measurement, it can also be diluted with (German) tap water.
Procedure
1. dilute the water to be measured with distilled water in the ratio given in the table and mix it thoroughly (for chlorine: do not stir/shake strongly, otherwise the chlorine will outgas)
2. Add 10 ml of this mixture to the cuvette for measurement
3. the measurement result must be multiplied by the factor from the table below The rule of thumb is: quantity of sample water multiplied by "x" = 10. "x" is the factor to be used.
Example:
2ml sample water plus 8ml distilled water = 10ml
factor calculation: 2ml times "x" = 10 "x" = 5 = factor
Extended measuring range according to factor | ...ml of sample water | ...deionized water / distilled water | Conversion factor | Example:
Measuring range (25 mg/l) x factor = extended measuring range |
2 | 5ml | 5ml | x 2 | 25 mg/l (ppm) x 2 = 50 mg/l (ppm) |
