I have a 30k gallon in ground pool (20x40 ft). I updated to a VS pump running about 45 GPM and a Rapack 406A heater (~399Kbtus).
While the pool generally heats up at around 1.4 F/hour, the return jet temperature does not seem that high. I get a rise of about 8 F at 45 GPM. I think that is roughly half of the expected value.
Is this normal or is my internal bypass diverting too much water? The UG is working fine but I did not toy with the header to figure out the bypass valve.
Any suggestions for raising the outlet temperature? We enjoy the hot jets on the stairs.
