This shows the expected temp rise (Y-axis) vs. Flow in GPM (X-axis).
The minimum required flow is 40 gpm.
So, the maximum temp rise should be 16.8 degrees Fahrenheit.
Water in the heat exchanger is +/- 105 degrees at all times. Whatever temperature the water is at the outlet is the result of the cooler and hot water mixing. So, yes it all gets heated, just not all directly in the heat exchanger, where, if memory serves, there is less than 10 gallons at any one time.All of the 45 GPM gets heated once it mixes at the heater outlet.
Thanks everyone. The install was 100% inspected as we redid the entire pool area, etc back in 2021.
