You wouldn't. The relay didn't necessarily malfunction, the contacts inside could be worn and therefore getting hot. If the heat didn't damage it, then it will test fine.How would I check the relays to see if they are faulty?
Test it with an ohm meter on the terminals, and from one terminal to heater housing with water in it. Post results.make sure my heater isn't damaged?
Fill it with the hose stuck down the filter pipe.How do I prevent an air-lock in the future?
