Heater Bypass Configuration
ejr2001r
Active member
Nov 24, 2019
26
Aldie, Va.
Hello fellow members,
We just had Jandy JXi gas water heater installed, along with a manual bypass. Unfortunately, the company that installed it didn't tell us they were here, and we weren't able to ask questions, so we don't know and aren't sure if this current configuration is safe to fire up the heater. Can anyone please take a look at the pictures and advise? We don't trust they'll come back by tomorrow to explain their work prior to the Memorial day weekend. Much appreciated!
1poolman1
In The Industry
Jul 14, 2014
4,146
Sacramento
If you want to completely bypass the heater the diverter is in the valve incorrectly. To do a partial bypass, turn the handle so that it points toward the pump. That will partially open the port that is now completely closed (see the label on the curved portion of the handle).
ajw22
43,730
Northern NJ
Pentair Intellichlor IC-60
The handle is in the correct position for operating your heater...
img_20230525_160837-jpg.496260
ejr2001r
Active member
Nov 24, 2019
26
Aldie, Va.
Thanks for the responses all. So to bypass it, I just need to turn the 3-way valve counter clockwise so the off is pointed more towards the heater correct? The valve only turns a quarter of the way in both directions, and I did notice the red flap in the clear valve move 90 degrees into what looked like a closed position.
