- Sep 10, 2021
- 14
- Plaster
- Hayward Turbo Cell (T-CELL-5)
I'm getting beyond frustrated with my Hayward pool heater. The pool service guy was out several hours last week trying to get everything running properly. The heater is a Universal H-150 heater running on propane. The heater itself was working fine as long as I ran it in manual mode. In bypass mode it just didn't seem to be getting communications that it needed to fire. The pool guy replaced the communication cable from the pump to the Omni Logic PL as it looked like an animal had chewed on the cable but things still weren't working. Finally realized there were too many pool heaters programmed in to the Omni Logic. After erasing all of them and setting up the heater again, things finally worked. The Hayward rep had him program the pump to run at 80% when heat was called for and that was working just fine. Our temperature dropped to 55 degrees last night and I woke up to a pool that was 75 degrees. The heater thermostat was set at 78 degrees so the pool temp shouldn't have gotten that low. I checked the heater and the fan was running but there was no heat. I reset the system and could only get the heater to fire with the pump running at 100%. Anything lower than 100% was giving me the LO error. I cleaned the filter yesterday so that shouldn't be an issue. I have a 250 gallon buried propane tank and it's probably 20 feet or less from the heater. The tank is at 30% and I'm waiting for a fill. The propane company came out last week but wouldn't fill it without an inspection first because they didn't install the tank. I don't know who installed the tank and filled because the builder didn't leave us that info.
Anyone have any experience with these heaters running on propane? Is my propane tank level too low at 30% and could that cause the LO error? Just to mention that this heater is less than a year old. Our pool was finished at the end of the 2021 pool season so the heater didn't really get to run and we only were able to get in the pool one time.
