I have a leak in this unit. The leak appears to be coming from about midsection. It is getting worse. What should be my first go to fix? I’ve searched the forums but didn’t find exactly what I was looking for. Any help appreciated. Thanks.
What brand of valve is it? The actuator is not relevant.yes I am
I don’t know what valve. It looks like all one unit.What brand of valve is it? The actuator is not relevant.
Inyopools sells rebuild kits for all neverlube type valves.
Valves - Further Reading
www.troublefreepool.com
Post a picture.
The actuator is held on with four screws. If you take them out to remove the actuator, do NOT put those screws back in the valve without the actuator. You will break the valve.
