I can run my equipment from my controller at the pump or from an app. I’m trying to keep my pool heated to a certain temp. I just heated it up to 85 for some warm days and I don’t want the water temp to drop below 70 again on the cold days. The problem I have is that I don’t think I can run the system based on the need for heat. To get heat, the pump has to be running. It also has to be running at a good rate - I think about 75%. I want the heater to turn the pump on when the water temp falls below a certain set point. Is there any way to do this?
