- Jun 24, 2021
- 15,880
- Vinyl
- CircuPool RJ-60 Plus
Well, she can take one. If it dissolves quickly, put it in the sock. If not, then...
What you are seeing is the power of SCIENCE!!!
I’m half tempted to try it in my tubs/sinks inside the house… I just had the interior filters replaced this winter and I’ve seen insane improvement since going up a filtration level but now I have older rust stains to contend with.
SCIENCE!!!!![]()
I haven’t had to add anything for CYA - so I’m not sure what to look for when going to the store. PoolMath says “dry stabilizer” or “liquid stabilizer” - so not a ton of direction.You might add 10ppm or 20ppm of CYA, 40-50 this time of year will help with FC demand.
Okay I’m at a 30 now, targeting 20+ is 50 ppm. Pool Math says 14 oz.Liquid is expensive and hard to use. The dry CYA is cheap and easy to use.
Add 20ppm of CYA, use the sock method. When the sock hits the pool your FC target goes up to CYA of 50. Link-->FC/CYA Levels
Do I get bonus points for using one of the “solos” from the laundry room? I have PLENTY of those!You get bonus points if you use a cute sock LOL
