- Mar 5, 2020
- 3,221
- Plaster
- Astral Viron V35
Keep in mind that chlorine loss is a percentage of the current FC. If you are loosing 0.5ppm at FC 6.5ppm, then you are loosing loosing about 8% of your FC per day. That means at FC 9ppm, the loss after day one will be about 0.75ppm. After 10 days, your FC will be at 9ppm x (1-0.08)10 = 3.9ppm, which is under your min FC.
As Marty suggested, bring it to SLAM, i.e. 20ppm in your case with CYA 50.
After 10 days, you should return to about 20ppm x (1-0.08)10 = 8.7ppm. That gives you enough buffer and starts with a clean situation.
