Did not add liquid chlorine when I saw that FC=3. Should I have?
SWCG is good at maintaining, not so good at raising. Raise with LC, maintain with SWCG.Did not add liquid chlorine when I saw that FC=3. Should I have?
Did we go over the FC needing to be under 10 to make the PH drop test valid ?FC 15.5
pH 8.0; added 4 Oz muriatic acid
Sorry for the slow response. I don't recall the pH drop test. Even last year I was hovering around 7.8 to 8 all season. I ran out of muriatic acid and did not have any to add yesterday.Did we go over the FC needing to be under 10 to make the PH drop test valid ?
(Sorry, a bunch of pages in we have covered some ground and I forget)
Ok. Just remember if you want to test PH, the FC needs to be under 10 to trust it.I don't recall the pH drop test. Even last year I was hovering around 7.8 to 8 all season.
Most excellent. Read onBut if you have a minute to guide me to a link addressing this FC with pH interaction, I would read on.
But then the PH is artificially lowered by the distilled waters PH, so it solves one problem and creates a new one.I understand how doing a 1 to 1 dilution with distilled water (pH 7.0) should drop the chlorine by 50% and make the Phenol red pH reaction more trustworthy.
Why’s it closed?FC 14.0 (turned down the SWCG). Pool was closed again most of the past couple weeks
CC 0
pH 8.0
TA 100
CyA 60 (added some).
