Well, it has been a while since I have updated. No real movement on the pool until the tile started on Monday (2 days ago), but I have been busy!
I know everyone says to run conduit because it is cheap, but I don't know if "cheap" is still the correct word. I knew if I didn't run irrigation and conduit for low voltage (and 120v in a couple of places), it would be very difficult to do later on, so this was necessary.
I have spent the past 2 weekends and every evening after work jackhammering trenches for conduit and irrigation pipe (using schedule 40 PVC for pipe and conduit). It is over a couple hundred feet of trenching after all is said and done. A few hundred feet in conduit and pipe (and some sizes were not easy to find).
Had to use a jackhammer to dig thanks to solid rock after a couple of inches down. Also with all of the rock that was compacted on my lot after blasting, getting a trenching shovel more than a couple of inches was almost impossible.
View attachment 420928View attachment 420929View attachment 420930
After digging down to 18" for the main trench, I laid conduit and irrigation pipe. Where I was going to run 120v outlets, I branched off trenches down to 12" burial depth (per NEC). and ran conduit. Also ran conduit for speakers, landscape lighting, conduit for HDMI at planned pavilion location, and conduit for misting tube for pavilion. I've been using a level to ensure the risers at the house are straight and I'll make sure the risers are straight when I backfill (each bump send the risers out of plumb as I add more conduit to a trench).
View attachment 420937View attachment 420931View attachment 420932View attachment 420933View attachment 420934View attachment 420935View attachment 420936
I will hopefully be finished with this part of my project in the next couple of days.
