What kind of pool do you have? Do you have a salt water generator? If not, your numbers are in a really good place, although your CSI may be a little high (assuming a water temp of ~82). I come up with CSI of +0.70 which is a little on the high side. Nothing major, but you could drop either the pH or TA a little bit more if you want. Otherwise, fire away with the boric acid.
I recently did that myself and have been very happy with the result. It really helps stabilize the pH climb, plus it is really noticeable if you have a SWG. It helps keep the salt cell free of scale much better than without it.
