Because we had some rough plaster upon opening this Spring, I thought I'd try adding borates (via boric acid from Duda Diesel) to hopefully keep it from getting any worse over this coming winter. I'm also hoping to stabilize my pH in general.
My water test results from today show pH of about 8.0 and TA of 100. I know I should lower the TA (I use muriatic acid) before adding the Boric Acid, but I'm unsure how far to go. If I lower my pH to 7.0 with MA, Pool Math app shows my CSI would be -0.68 ("suggests corrosion is likely"). At pH of 7.2, CSI would be -0.49 (still in the "avoid for prolonged periods" range). Those calculations are based on a water temperature of 65F, but with our overnights getting cold, water temp is going down pretty quickly.
What do y'all suggest I do with my chemistry before I add the boric acid?
And I confess I went to the pool store this afternoon to "verify" today's test results (HA!), and they show my TA as 42. That's so wildly different from my reading of 100, I don't even know what to think!
I think I have my Pool Math settings set for TFP members to see my results.
