Hi!
I've owned a pool for about 10 years now, but have only used test strips to keep an eye on water quality. My track record is spotty
This year, more as a learning experience and for the pleasure of it, I designed my own pool monitoring / chlorine injection system (uses sodium hypochlorite at 10.8%). ORP and PH probes are well-calibrated (orp reads 470 mV in 470 mV solution, ph reads 7 & 10 in respective solutions).
I am now suddenly exposed to how much stuff is going on in the water, and find that I need advice from more experienced people to keep things in check.
Had a water check done yesterday morning at 10:00:
Volume is roughly 10,000 gallons
Free chlorine: 1.54 ppm
Total chlorine: 1.76 ppm
CYA: 29 ppm
PH: 7.6
TA: 96 ppm
Calcium: 190 ppm
Here, at 11:00 I am adjusting PH down by adding "PH minus", presumably some acid, in crystal form, to bring PH down to 7.5 or so.
What is surprising to me is that it has climbed back up to 7.8 or so overnight. Water jets were oriented upwards, which I suppose could introduce air, and increase PH. Blue marker is when I oriented them down. So, that's question 1. What else could explain this?
Now ORP:
Test strips indicate 1PPM chlorine at the moment (added 250 mL chlorine yesterday evening, water currently registering at ~686 mV ORP). I am thinking it's maintained through the night, then sunrise and chlorine breaks down (?):
So, again, in short, just want to double check that this makes sense, and get some advice on PH observations/management.
Thanks!
CYA: 29 ppm
PH: 7.6
TA: 96 ppm
Calcium: 190 ppm
Now ORP:
Thanks!
