I’m currently in Dallas where it is and has been sub 20 degrees and will be for at least the next few days. I have a large inground pool and spa.
Previous to the bad weather starting I was away from my home and came back to bad conditions and a pool and spa that has started to freeze over. The pool pump had probably been off for a day or so beforehand.
I went the equipment and tried turning the pump on with no luck. Unfortunately the pool capacitor has gone out and I can’t start. Alongside this I read up and opened filter air valveand also took lid off the pump and turned it off at the mains.
I couldnt turn the backwash valve off of filter as it had frozen. Tried to put this in between settings but no luck.
I’ve checked the pool a few times and made sure it’s not frozen around the skimmers and we are ok for now. Weather will only get worse before better and I will be without a pump until it does.
I wanted to know if there was anything else I can do now to make sure I limit any damages etc to pool and equipment?
thanks
thanks
