Hello fellow members,
I just bought a house with a huge pool, about 36K ig vinyl pool. I thought hiring a contractor from local pool store will take care of everything but I guess it's not that simple.
A week ago, I had the guys from the local pool store "open up" the pool for $320. I wasn't home at the moment but my wife said they poured a big bag of shock, ran the pump then left without further instructions.
The pump was left on for two days. As you can see from the photos, there are still leaves and a bunch of algae inside. Also, the flow to the skimmer doesn't seem strong enough. When I called to inquire, they said they do not clean or vacuum but only remove the cover and run the pumps. I was told to find someone to clean and maintain the pool.
That's when I started some research and found this forum. I evaluated all the systems in the pool house. There are 3 pipes going to the Hayward pump, two skimmers and one main drain. Pentair FNS PLUS 48 DE filter with separation tank. Raypak water heater.
Here's what I've done so far. 1. ordered TF-100 test kit and Dolphin Nautilius robot. 2. Collected leaves from the surface and clean the skimmer and pump filter.
Today, I also noticed the gauge on the DE filter was at 0. I figured the filter might be clogged and attempted to follow the cleaning procedure in this forum. As soon as I released the air relief valve, water started to overflow from the pump cover so I closed the valve. Is that how you relieve the pressure? Is the procedure different for a system with the separation tank?
Meanwhile, what else should I be doing until the test kit comes?
