Do you need a flow switch for all SWGs? I am looking at different models at discountsaltpool.com and some come with a flow switch and some don't?
After looking at hundreds of these set up photos I have come to the conclusion that one of two things is going onThe orientation and proximity of all your pipes is rather annoying
I do have my pump on a timer. I am assuming I would hard wire the SWG controller to the timer as well so it only kicks on when the pump is running?
I think the SJ SWG have the pipes entering the bottom of the cell, so you do not need as much of a straight pipe to fit it. But, I am not sure what they use for a flow switch and where it goes. Also, I think I just read that you need a minimum of 30 GPM for them to work correctly.
The RJ installs like the Hayward and Pentair where the cell is inline with the pipe. The Hayward has a separate flow switch that is also installed, not sure if the other 2 are the same. Advantage to these is they only need about 15 GPM for them to work, so a 2-speed on low or a VS pump would work.
The gas sensing tang is on the side of the cell close to the top. The power supply monitors it for voltage. If it is covered with water, the power supply will see voltage when the cell is powered. It will simply pick up the stray voltage from the electrodes in the water. The gas sensing tang is simply a piece of titanium welded to a wire there are no moving parts so it is about as reliable as you can get.
In Australia It is a code requirement to have a gas sensor (like the paddle switch, or our gas sensing tang) but it must also have a gas trap as well.
Safety features of a salt chlorination system
