I have installed FOUR well points and pumped them simultaneously from directly under the deep end, and it wasnt really enough to keep my water table at bay. This is part of my frustration from earlier in this thread, dealing with the rain and high water table.changing the subject a bit.......are you thinking of a well point (pump) to keep the water away from your pool?
What I've decided on since then, is using a dewatering system I've seen on the internet quite a bit. I whipped up a 5th grade level Paint drawing to explain.
The other big help with the ground water problem is simple. I'm going to give up a foot on the deep end. After talking to people, there seems to be no real benefit to extra deep pools if you don't dive.
With these two measures in place, and a very overkill footing for the walls, I believe I can overcome the challenges with the water.
