Does someone make a flexible hose that can be clamped at each end to connect a mis-aligned 2" waste line? I used a rubber boot thing, it has started leaking.
The connection to the multi-valve is a "used" slip fit, so that needs a clamp unless I want to replace the whole valve. Just need something more durable in the sun than black rubber. It's low pressure waste, so could be about anything. I just haven't found "anything".
I was thinking something like discharge hose, but not sure if it stretches over 2" PVC. I may just buy a new rubber coupler and add a couple 45's to the line to line it up.
Decided to just buy another 2" rubber coupler, paint it white, and a couple 45's to line it up. The problem was the clear piece of tube that must have come with the multi valve was bonded to the valve and cut off at about 3/4". This seemed an easy fix.
