I am so glad you got the kit and used it already!! NICE JOB!
I don't see your PH though.
How does your water look?
I do see a couple of problems with your numbers. Your CC and CYA are higher than we would like to see.
Have you found and played around with Pool Math? Here is a link just in case you have not:
PoolMath
I am going to share another link that has the levels we recommend for a well balanced pool:
If you water is looking okay (no green) then this will be a fairly easy fix.
The main thing is to find out just how high your CYA is. With the CYA test only going to 100 it might be higher. Here is how you do a test to find out just how high it is:
Add pool water to bottom of sticker.
Add tap water to top of sticker.
Shake.
Pour out half so mixture is to bottom of sticker.
Add reagent to top of sticker.
Shake.
Test outside with back to sun and tube at waist level.
Pour back and forth a few times to see if you get the same result.
Double the result.
How are you adding chlorine to your pool right now? I am thinking it has been tablets/pucks. I want you to look around your area and find your easiest way to get liquid chlorine or bleach (PLAIN bleach, no pretty smells or splashless).
The pucks add CYA to your pool. The only way to remove CYA is to remove and replace water. That is why we use liquid chlorine or SWG. Here is a link to SWG:
Pool School - Salt Water Chlorine Generators
I hope I did not overwhelm you
Your pool will look better than it ever has before AND your wallet will be fatter as well!
Kim
