- Jul 21, 2013
- 65,062
- Plaster
- Pentair Intellichlor IC-60
Don’t obsess over it. The CYA test is a very coarse test. There are better things to do with your life.Question everything...story of my life. Lol
I need to see things for myself, even if it means spending hours messing with stuff. I probably did 10 tests just to see how temperature affects CYA readings.
Im done for tonight. Ill play more tomorrow. Thanks again.
+/- 10 ppm accuracy is just fine for our use of CYA. Make a call and move on.
You find a CYA reading and value that works in your pool and use the test to repeat it. It does not matter that someone else runs the test and calls it a different number then you.
Focus on the desired outcome, which is the daily FC consumption. Not on achieving some CYA number which is meaningless.
