- Jun 24, 2021
- 15,970
- Vinyl
- CircuPool RJ-60 Plus
Did you use the smart stir with the drop test? Bottle vertical, and let the drops drop from their own weight without squeezing them out rapidly? If so, you drop test is the most valid.Just got around to buying the TF-Pro test kit for salt and wanted to double check the electric salt tester, which was showing 3200. The drop test is showing 4400ppm. The SWG has never been on, only time salt was added to the pool was when it was completed in September.
Yes, but is your SWCG working? If so, no need to drain.Looks like the only way to lower the salt is to drain and add more water?
If you do need to drain, read "no drain water exchange" here:
Draining - Further Reading
