First time slamming question as to timing
Julie8000
10
Houston, Texas
I have drained and refilled and just added acid to lower the ph prior to start adding chlorine. what Would you recommend as to the time of day to start adding the chlorine I am in Houston area and it is hot and sunny. since it says to test numerous times a day, should I start first thing in morning or does it matter. Thanks
mknauss
32,637
Laughlin, NV
Try to test at least 3-4 times per day. So it is 5 pm there. Test at 8 pm and add chlorine. Then again in the early am.
