That is so beautiful!!!
Your instincts are 100% correct, IGNORE the SWG's FC suggestion and follow [FC/CYA][/FC/CYA]. Dial in the SWG so that you're still in the target range before bed each day. Remember that you're still safe to swim as long as you're staying under the last column on that page, the Shock/SLAM FC. So when in doubt, hug the high side of the target range. If you are passing
Overnight Chlorine Loss Test, there isn't a need to go higher than the high side of the target range, unless you're expecting a lot of swimming (bathers lower FC), so if your pool is going to be getting a lot of action, feel free to target 1-3 higher than the target if you want to avoid having to add some bleach. All up to you. No matter what balance you strike between bleach and more SWG, the goal is: most of the day spent in target range or a little higher - none spent below min.
This time of year here in Florida, the wind blows in dirt/sand daily, and since I only run my pump a few hrs a day, some sinks to the floor. No worries because I have enough FC in there to handle whatever bacteria comes along. I'll vac it once a week or two and all is well. I can brush it mid-week if I wish to spread it out so I don't have to look at it.
I'm also curious how long and often to run the pool rover but I can look on other posts for that I'm sure.
is this a robot or manual vac? If robot, yes, other threads or someone else can answer that one - robots are something I haven't gotten into yet - I like the manual vac for now.
