I have managed to stump two pools stores with my pool...
HELP - MY POOL IS MILKY WHITE CLOUDY AND WILL NOT CLEAR. I have done several treatments of phosphate remover and metal remover. My pool cleared up after the initial fill with a good reading on my water and the metal remover cleared it up. After using it one week it started to become cloudy and never cleared. If I scoop water out of my pool and let it sit for 24 hours it clears up and I get a white whispy film on the bottom of the cup. If you slightly shake the cup it blends with the water quickly and it becomes cloudy. I run my filter 24 hours a day and I have backwashed my sand. It is very cloudy. I have vaccumed my pool. I have a Volt. I have stirred up my pool with a brush to try and filter out the cloudiness. Nothing.
5500 Vinyl Above Ground Pool - Started with a cartridge filter moved to a 50lb sand filter with about .3 HP - I am moving up to a .75 HP sand pump with 120lbs of sand #20 silica
My pool water reading from this morning from one store is (they have 7646 for gallons listed on my account which isn't right):
8.56 FC/TC...pH 7.79...Hardness 250ppm...Alk 179 ppm ( this is showing high but the other store said I was low so I increased it)...CYA 27ppm...Copper .2ppm...Iron .1ppm....Phosphates over 5500 ppb
