Would those suffice in lieu of liquid to get me through until the test kit arrives?
First things first. Breathe. Relax. It's ok. Nothing is super urgent, the pool isn't going to fix itself in an hour, or get horribly worse in a day or two.
K. Better ? Good.
These guys are the real deal - honestly. If you take a little while, read up on the Pool Care Basics, and specifically the SLAM process, you'll be ready to 'fix' your pool once and for all.
All the questions are simply so they can figure out the easiest, cheapest and most effective way to turn your mean green into cool blue.
Depending on WHAT those 'packets' are, depends on whether you should add them. If they contain 'sodium
dichloro-s-triazinetrione' or 'sodium
trichloro-s-triazinetrione", then those will add to the stabilizer (Cyanuric Acid, or CYA) and that usually makes fixing the problem harder...
If they contain Calcium Hypochlorite (commonly called Cal-Hypo) - then that is better, but also adds to your calcium hardness - which is probably less of an issue, but why add stuff you don't need ?
Bleach is Sodium Hypochlorite - basically Chlorine + Salt + Water. Thats why it's preffered, as it adds very little that can HURT your pool, while working to sanitize it at the same time.
Not all Bleach is created equal. Basic, 6% or 10% bleach is fine, as long as it has NO fancy stuff in it (the cheaper the better usually). Walmart, Lowes, HomeDepot or Menards usually sell 'Liquid Chlorinator' which is usually 10% or 12% bleach.
The Test Kit once it arrives will allow you to measure just how much you have of all these things in the pool, so you then only need to add what is needed. Pool Stores exist to sell you expensive remedies, usually to problems they create with their expensive remedies. Trust in the process...it works, and once you understand how to do it yourself, you'll never look back.
Congrats on the new house, and the new pool, and stick with us, follow the advice, and you'll have a crystal clear oasis of joy in no time flat.
Speaking of which, I'm head out for a swim
