- Jul 5, 2024
- 33
- Vinyl
Hello everyone.. I'm hoping, better yet I know someone here has to have the answers to set me free after I've been on the struggle buss googling and trying to go it on my own.
I purchased the INTEX Rectangular Ultra XTR® Frame Above Ground Pool w/ Sand Filter Pump - 24' x 12' x 52" which came with the QX2100 (eco15110-2).
I followed all the instructions on pool setup and pump setup and everything there is running just fine. Once it was all setup I did as instructed and added the 210lbs of salt to the pool and let it dissolve over 24hrs ensuring I went out and brushed it around to help.
After the 24hrs I checked the salt levels and I'm reading 3010ppm. I then ran the Chlorinator for 8hrs the first time because that is what's recommended by the manual. The following morning I came outside to test the water and I'm registering NO chlorine of any kind across the board, I'm getting NO Alkalinity, NO Hardness, pH sits at 6.3.
I did some more googling and somewhere I read that the Chlorinator needs to run longer, so last night I ran it for the max, 12 hours and again this morning I went outside to check and nothing has changed on the readings.
I honestly have NO idea what I should try to do and I'm open to any and all suggestions.
