- Jul 5, 2024
- 33
- Vinyl
Will do! Next test is coming up at 1pm (15min)Squeeze some air out before you invert.
Thanks!!!Well done! You are heading in the right direction! Don't back down now. You can move to every three hours for the rest of the day.
For work you can get a few tests in. Once you wake up (after coffee of course LOL), before you leave the house if is a bit after you get up, as soon as you get home, after dinner, and one more time before you go to bed.
Kim![]()
I’ll add some photos, wasn’t sure what to send a photo of
It's microscopic. By the time you can see it, it's way too late. So you trust the testing which gives you the early warning while you still have the upper hand.confusing but as you all informed me there’s invisible algae!
You need:So where do we stand on the OCLT this morning? The pool suffered a substantial loss in FC dropping from 12ppm to 5ppm over 10hrs (8pm to 6am) BUT the CC did drop from 2.5ppm to 1ppm…
Thanks!!!It's microscopic. By the time you can see it, it's way too late. So you trust the testing which gives you the early warning while you still have the upper hand.
You need:
Clear water (Check)
Overnight FC loss 1 or less (not yet)
CCs 0.5 or less (not yet)
Slam on.
As always killer advice on the air with the bottle! Didn’t drop too bad. Registered 11.5ppm so bringing it back up to 12ppm and I’ll check again at 3pm
As a new pool owner, I'd raise it to 60 and run it there for a while. If you have to slam again, much easier than 70 or 80 CYA.Raise the CYA slowly! To 75ppm which is recommend for SWG start running my chlorinator at night for 12hrs again I believe that’s what recommended for my pool/pump.
Thanks! Ok my lack of knowledge will shine again. Where would I find out the actual output or info on my SWG? I attached two photos.Congrats!
You can run the pump 12 hours, 24 hours, whatever is needed. Use pool math "effects of adding" to get a pump runtime and % output that will add about 4FC daily to start.
