First pool build! Excited but apprehensive. Bid included
ajw22
16,470
Northern NJ
I'm going to have to do research on why SWG over chlorinators as well. Make a business case to present to the wife.
nuke_twidget
21
Houston
Equipment list:
Filter-Pentair - Clean and Clear Plus CCP520 520 sq. ft.
-Heater-MASTERTEMP HIGH PERFORMANCE POOL HEATER model460736
-Pump-IntelliFlo VSF
SWG - IC40-IntelliCenter System Load Center i8PS, IC40, Common Load Center (w/ Salt) -- Model Code: 8PSIC40
Got them to upgrade to the 520 filter at no additional charge. The Microbirghts and Globrights are interchangeable at no additional cost to us. They did mention the Microbirghts are more directional vs the Globrights which have a wider beam.
ajw22
16,470
Northern NJ
Should I even consider IntelliBrites since I'll be doing the Intellicenter controller?
MicroBrites are the latest model Pentair LED light. All the past models have had reliability issues. The MicroBrites fit in a standard 1.5” pipe that gives you options to change to other manufacturers lights in the future. We have yet to see data on MicroBrite reliability.
Spookie
67
Highland, CA
Alright, I can deduct $7k from the price for the in floor, SWG is $1695, and going to the Intellicenter is $2300. The Pentair 520 and microlights are no additional charge.
$2,660 includes the salt cell
Reactions: nuke_twidget
nuke_twidget
21
Houston
Spookie
67
Highland, CA
IC40 is more than double your 15k gallon pool so you are definitely good. My builder had never heard of IntelliCenter. I showed them the price and they just charged me cost..no issues. They also never heard of microbrites. Microbrites don’t suck.
nuke_twidget
21
Houston
Update: Contract signed! Removed IFCS, went with the IC40/IntelliCenter bundle (their also installing a chlorinator as a backup at no additional charge), swapped all lights to MicroBrite, a Pentair 520 filter, 6 jets in the spa with a 2HP pump, separate water feature pump, autofill and overflow, etc. All for under $80k now! Next up, construction photos!
Jimrahbe
17,154
Bedford, TX
MT,
I assume you mean you got a 2 HP pump for the spa... If you really mean that you are no longer going with the IntelliFlo (3 HP) pump, that is a huge mistake. The IntelliFlo is the only style pump the automation can control. The only other Pentair VS pump is the SuperFlo VS and you cannot control it using the IntelliCenter.. The SuperFlo VS has no RS-485 port.
