For 5 days straight my DE3620 filter pressure will run at 13-13.5 psi (which has been my normal) until very late in the afternoon.
Today it read 13.5 at 3:15, checked again at 6 and it was just a tad under 10 psi.
The pump strainer has a periodic short burst of very small bubbles at the very top of the glass lid every few seconds (not continuous bubbles)
Bubbles are very hard to even see unless I get nose to nose with the pump lid.
Assume I have a small air leak. But wondering why it would only drop psi late in the day after running steady and normal all day.
I checked the return eyeballs for tightness, checked cleaned and relubed the pump stainer lid gasket.
Vac Pool cleaner and returns are running at normal strength.
Is this something I should worry about if the late day psi drop doesn't get worse than the current 3-4 psi drop.
Thanks
Thanks
