I have a couple problems right now - pump motor is tripping the breaker and I think it burned out when the filter lid came off last night.
I went to my pool last night and saw quite a bit of water loss - way below the skimmer.
The pool lid was off so I assume the pump expelled water from the filter housing until the pump burned out.
I think I smelled something like burnt electrical stuff at the time, but I wasn't sure.
Visually everything looks ok at the pump equipment. Inside of filter housing looks fine.
Of course one problem is why the lid blew off - I'll tackle that after I figure out what's wrong with the motor.
I'm thinking/hoping it was due to it being cold that night and I usually don't run the pump at night.
Maybe I didn't tighten the lid ring enough? I remember trying to do the minimum (it was a couple months ago)
I have two breakers in line of the pump - one at the house panel (50A) and one at the pool panel (15A). The pool panel breaker was tripped this morning.
After I reset the pool panel breaker, (and of course put the filter back together)...
1 turn on pump relay
2 hear click of pump relay but the motor makes no sound
3 breaker trips
I'm going to take the power wires off the pump and test with a voltmeter - but I'm pretty sure its the motor (or pump).
could there be other issues causing this - for example are there any parts in the pump body that could be siezed up?
its a whisperflo
3 breaker trips
its a whisperflo
