Don't even know where to start here. Well, see the pictures.
Some background story:
- Both the filter encasing and the cartridge not more than 3 months of usage.
- Pool recently resurfaced (November 2018)
- Big areas of decoloration after the 30-day curing process (proper chemistry kept and daily brushing)
- Both pool builder and material (NPT quartzscapes) representative came to inspect. "you need a scaling treatment"
- I did the scaling treatment using Jacks Magic #2. Keep chemistry and followed instructions per specs. Specs also call for adding their sequestering agent (Magenta stuff) AND keep low pH, low alkalinity, and low chlorine.
- After two weeks not much changed. Contacted Jacks Magic representative. "Add more magenta stuff (sequestering) and let's keep a close eye on it. While on it try our filter stuff to better capture those particles the agent is encapsulating". I have to be honest, I don't know how he convinced me on this one, I should've known better.
- The last filter clean no more than two weeks ago. (as specs call for cleaning filter regularly, along with 24/7 pump)
- Of course in the middle of this, algae bloom because Chlorine needed to be kept very low per "specs". Shocked with liquid clorine with eyes closed. Couldn't do SLAM because per Jacks Magic rep the free chlorine read would false read because of the scale treatment. I'm still fighting algae...
and then......today......... when I went to clean the filter, I noticed it was almost over 10 psi over normal clean psi (red line)...opened, and this is what I came to.....
I'll post test later on today, the last set of tests was alkalinity around 20, pH around 6.5, calcium around 400, cya 60, cl don't know how to test. I know my numbers are not where they should be but again, following the directions on the Scale treatment specs (they ask for free chlorine between 1-3, pH low in the 6s, alkalinity low between 20-30, calcium increasing "is a good sing, the treatment is attacking the scale" said the rep).
Ideas on why this filter exploited? (or imploded?).
PS; needed to vent this out...thnx for reading...
