We will soon be buying a 4 person spa from Costco, I am just starting to read about caring for a spa and have few questions..
I keep the pool CYA level around 35-40, TA stays around 60 with a pH near 7.8 if not slightly lower, CH around 600 due to fill water build up.
Does anyone see any problem with filling and/or occasionally refreshing the spa by draining into and refilling with pool water, will the high CH be a problem? If I should not fill with pool water can I still drain into the pool as a way to not waist water?
how often should I drain and refill the spa?
Anyone tried an aftermarket SWG for spa like a Saltron would you recommend it if so what brand. My presumption is that a SWG for a spa might be good to maintain FC day to day while not in use, but I will still need to manually add for every person hour of use is that correct? Would a stenner be a better option for ease of dealing with fluctuations as well as allowing for less filter pump run time?
how many hours per day should I run the filter?
Thanks for any advise.
