Whew. Busy day. Got all of the plumbing done aside from the pieces that will connect the 3-way valves. Even had to make a last minute Lowe’s run to grab another 1/4 turn valve.
The existing plumbing was wasted, leaks, shoddy repairs(not by me). I took it all out, down about 12” below ground and replaced with new.
The equipment is about 4’ below the surface of the pool. I built some plugs from pool noodles, 1/2”x6” bolts and some paracord. Was able to make the cuts, plug the flood and then stalk on using couplers in the dry pipe above the plug. I added 1/4 turn valves on all 4 return and supply lines. They are going to cure over night, then I’ll pull the plugs out through the valves in the AM and close the valves to finish the plumbing. Those valves should have been a part of the original build plan.
I was able to locate the equipment so that I have room to add a prefilter later if I choose, and a heater as well. Gave the ChlorSync the 15” of straight pipe before the inlet as listed in the manual. The coupler flanges for the pump inlet and SWG outlet line up nicely albeit at different heights, which I’m fine with. Ended up using the long sweep 90° fittings, mostly for aesthetics I guess.
Brushed in a jug of 10% at 0630, 330pm and 1030pm. FC was setting at 11.5 ppm tonight before I added the jug.
