Day 4 was trying, but the outcome was good. I'll write up a report tomorrow morning, as today was exhausting. Half day tomorrow to finish up.@robertwest Any updates today? I've learned a lot following this thread ?
Rich, The braces were removed the next day, so there's no wood buried in there anywhere. As for lateral braces, I can see how you would think that - it makes sense. But what happened when they put them in was it created a pressure toward the water side and it held really well. If you read my final post, they left the flowable fill overnight, so well past the 2hr minimum.The end result of a straight and level pool with proper backfill and plumbing is the the important thing at this point. As a future reference issue I would never approve of the burying of any type of wood. Simply put, at some point that wood will rot and create a void. Probably not a big issue in this situation but they could have simply scheduled things accordingly and waited the 2 hrs as Jimmy recommended for the flow fill to set up or used cross bracing to the other side. I am surprised not to see any cross bracing in place.
I hope the 'guy working on your pool' (using the term 'pool builder' would be a insult to a professional pool builder) is paying for the flow fill, New water and all of the required stone for back backfill. This would definitely be his responsibility.
I know this board goes back and forth about that, but the pipes have 1/2 inch foam wrapped around them between the pipe and concrete. The PB wouldn't do it unless they were foam-wrapped.I think the builder should be named. You may be all right with the effort that it took you personally to get the job done right and the huge extra expenses but a lot of us wouldn't be. I give them no credit for eventually 'doing the right thing'. How could anyone interviewing builders be be OK with loading that contractor into that gun for a game of PB russian roulette.
I like how the pool came out but I would never have encased those pipes in the concrete pad.
Do it! Do it! Do It!Wow, what a great image. It's polar bear time!! Come on, we dare you. Now THAT photo would be epic!!![]()
Not sure I understand what's happening here. I assume this pool is used through out the winter too. Can you please explain to your east coast neighbors how's this been done. How's the water being heated ? automatic cover as it doesn't look like? How's the equipment pad protected and all the rest that makes that picture beautiful. Need to say thanks in advance for this one. Have a client begging for this sort of idea but didn't see it possible.
