Please post your friends currebt pool details (size, shape, equipment pad items, filter, pump model, etc, etc). Pictures of the pad would help. We'll go from there.
Thanks JoyfulNoise, I will try to get all that info and will report back.
Bromine......Please do some searching on water mold. I will do some asking around but my gut says this will be a no-go for your daughter![]()
Bromine in a pool is a non-starter. We see bromine pools occasionally as it was a popular thing to do in the 80's & 90's until people realized how much of a PITA it is to maintain a bromine pool. 35k gallons of water would have to be dumped BUT you can't do that with a vinyl liner pool as the liner will be wrecked if you drain it.
The DE filter is fine (that model is a bit old) but the pump might need changing for efficiency sake. Brominator has to go.
PRS is designed for sand filtration systems. You wouldn't want to use PRS with a DE filter or else you'd gum it up pretty bad.
Technically, using a DE filter should be the equivalent of using the PRS system. A sand filter only has a particle size filtration spec of about 20-30 microns - much, much larger than a crypto parasite. So the PRS system acts as a coagulant to bind up all the suspended solids (and parasites) into larger clumps so that a sand filter can clear them. A DE filter, by contrast, uses diatomaceous earth as the filtration media and that has a particle size spec down to 3-5 microns. So, in theory, the DE filter should be able to trap free-floating crypto in the water. DE filters, on the downside, sometimes need a lot of baby-sitting and can require frequent backwashing if the filter size is too small for the pool. As well, DE filters must be recharged with DE after every backwash and many people don't like to mess around with DE because of fears associated with it being a respiratory hazard (although those fears are entire overblown).
Switching between sand and DE would be up to you and your friend but, if you do go to sand, you will need the PRS system which will be an on-going expense that most sand filter owners never have to contend with. Also, given the age of that filter, it should be taken completely apart and thoroughly inspected for operational soundness (DE grids are intact and not damaged) as many DE filter owners neglect them.
Your SWG is too small. For the most efficient/longest service life we recommend a SWG that is 2-3X bigger than the pool.
I would also compare your UV sanitizer with a Paramount Ultra UV system. The Paramount systems can be extended to 4 bulbs running at once to give very high UV-C fluence.
Agreed. At 35,000 gallons, you'd be hard-pressed to get any SWG to put out enough chlorine. Maybe a Pentair IC-60 could do it, but that would be on the edge.
You might consider liquid chlorine injection using a Stenner pump.
Daniel,
I had a best friend who's daughter had the same condition...32 years ago! Has a great life and has birthed 4 children. She received her liver from a donor.
Just trying to possibly ease some of the anxiety for your family. Best of luck on your pool endeavor! Prayers for all of you![]()
Got it. Two potentially very stupid questions regarding chlorination:
1. Can you install two SWGs in line or in parallel to keep up with the large pool size?
2. Could you install a chlorine injection pump in addition to the SWG to mitigate the insufficient output, or does it have to be one or the other?
And another potentially very stupid, but similar, question regarding the UV lamp: I am only finding the 2-lamp variant (https://www.amazon.com/dp/B015091DWE/). Would installing two of those double the benefit, or would it just be redundant?
Thank you again!
