Hello,
I am wondering with which way of pump operation the SWG Life would be enhanced. Is it the hours it works or the total output it performs?
E.g. a pentair would produce 1.40lbs chlorine / 24 hours.
Does it make a difference if the pump is on 24 hours and the SWG put to e.g. theoretical to 4.16% or if the pump runs 1 hour and the SWG is put on 100%. Both settings would produce 0.58lbs chlorine. So is the higher setting and shorter run time better or the longer run time at lower setting - or are they equal for the lifespan of the SWG?
Manufacturers give life expectancy e.g. 10000 hours which makes me worried to go to a low filter pump speed with extended working hours.
