I just added a Jandy APUREM unit and a PLC1400 cell. The first 24 hours I ran it at 50%, and when I checked the FC it was at 3. I bumped it up to 70%, and now 24 hours later, it is at 3.5. It seems like I should have more than that. I'm running the pump 12 hours a day at 2400 RPM (Max 3450). Salt is at 3200ppm. Although my pool builder said my pool is 13K gallons, I suspect it is closer to 18-19K gallons due to how much chlorine or salt I've had to add to get correct numbers in the past. Anyhow, I'm hesitant to bump it up to 100% as to keep its life longer. Higher RPM, longer pump time, or cell running at 100%, what do you all suggest?
Thanks!
Thanks!
