Post a picture of your pool equipment layout and plumbing. I'm looking for some layout ideas and would love too see what people are working with. Any issues with your current layout you'd change?
Do you drain your cartridge filter housing with the bottom drain plug or do you just separate the two halves? Most I see have the plumbing coming out of the side, thusly the drain is on the side. I would think that would make it more difficult to access for draining the filter during cleanings?
The constraints for my pad were such that I had to fit a lot of stuff in a 38" wide pad, but I had plenty of length. The total length is 19', with about 12' being used for equipment and the other 7' being used for storage and my robot. I used AutoCAD to lay everything out (along with the entire pool plan, including plumbing, electrical, drainage, etc.). I went through about 10 different iterations before settling on the final plan for the pad. And even then, I've modified the layout a bit since completion. I must say it was absolutely nerve wracking making sure the 7 risers were in the exact right location, which was necessary since they were going in concrete (no chance for error). I must have measured and adjusted them another 10 times before pouring concrete, but in the end, it worked out thankfully!
Obviously, I strongly second Kim's suggestion to use unions on all risers at grade as well as equipment (which usually come with them anyway) and also anywhere else it may make sense (i.e. ozone injection manifold in my case). It makes it so much easier to work on your equipment and make modifications later if needed. One tip for these is to invest in a rubber strap wrench for tightening/loosening. Also make sure the o-rings and faces of the unions are clean and in good shape before tightening.
I will also mention one thing (in hind sight) I wish I would have included is a pump-down line off the discharge of the waterfall pump that ran out to the ditch behind my house to allow for a quick(er) way to lower the pool level during a real heavy downpour/hurricane. Currently, I hook up a hose to the hose bib on top and run it to the back ditch. It's a 10 minute effort and I only have to do it once every 4-6 months, but being about to throw a valve instead would have been much nicer and worth it.
Just finished mine. Still need to do landscaping.
Is your equipment on a composite/plastic pad? That's what I'm supposed to be getting, but I'm weighing prepping the area with pavers.
