I'm redesigning the plumbing for my pool due to a change in layout. My 3HP VS Pentair pump is now positioned about 1 foot above the water level, while the filter, heater, and chlorinator are located 4-5 feet above the waterline. Unfortunately, I can't reposition the equipment to be closer in height.
I’m concerned about check valves because the strong spring inside them seems to add significant resistance to the system. To minimize this resistance, I’m trying to use as few check valves as possible. Currently, I have one installed between the heater and the chlorinator.
Given that the filter is 3-4 feet higher than the pump, do I need another check valve between the pump and the filter? Thank you.
