- Jul 16, 2019
- 686
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
I’m from Howell, NJ area and I open last week of March. Last year I opened on March 24th and was swimming on the 26th. This will be my second season. Looking forward to it.
How's your gas bill? I bought a house with a pool and heater but haven't used the heater yet thinking heating the pool will be expensive.
I realize this question was posed to someone else, however in Northern VA I typically heat my pool over night or for around 10 hours bring the temps up about 15 degrees or so. I estimate its cost approximately $4 an hour to heat. Depending on how cold it gets this will normally keep the pool warm through the weekend.How's your gas bill? I bought a house with a pool and heater but haven't used the heater yet thinking heating the pool will be expensive.
I like to keep the water temp around 80-90 from March up until October. I also have equal payment plan it’s about 150-200 per month all year long. This year I’ll look into a bubble wrap cover to help retain some heat over night hours.How's your gas bill? I bought a house with a pool and heater but haven't used the heater yet thinking heating the pool will be expensive.
I thought u couldn’t run a ng heater under a certain temp? How do u run it in March?
. So if I open at 32 degree water I can warm it up to 70 but then have to maintain it there?You can run a pool heater as long a you keep the water temperature above 70 degrees.
What you do not want to do is constantly let the pool water temperature drop below 70 and heat it back up, or use the heater to heat the water between 40 and 60F to keep it from freezing for example.
Heater Condensation - Further Reading
www.troublefreepool.com
