You could probably take the pump apart and unscrew the housing from the threaded fitting.
Alternatively, you can cut the housing by cutting down and around the threaded fitting (like a U shape) and then unscrew the part from the threaded nipple.
Hmmmmm... I'm tempted to look into the Superflo VS. Almost a drop-in replacement for the Challenger currently in place. The inlet is 2"+ lower than the Challenger's. Guess I could raise the pump up on a 2' square paver.
The pot strainer on the Challenger is the only original part of it left (and the seal plate), so likely that would be the next part to fail. Makes dealing with the inlet side plumbing worth considering at least.
Pulled the trigger on the V-Green 165, new impeller, new diffuser, and seal kit today. Luckily, its cooling down here now, so won't be such a swamp when the parts arrive.
Installed the new VS motor yesterday, and am already enjoying how much quieter it is. Even when running at top speed.
Thanks again for all the advice. Now I need to figure out the optimal settings, so back to searching the forum
We are glad you have found our information helpful. Please, if you can, consider making a donation to TFP.
We are staffed by volunteers and are registered as an IRS 501 (c) (3) charity and donations are what keeps the forum operating without advertisements.
I recently replaced my Hayward SP2610X15 1.5 HP motor with a V-Green 165 variable speed pump. The installation was pretty easy and I set a schedule and left it running. About three days later we had a hard rain and when I checked it a few days after that I discovered the the pump had tripped its...
I have learned everything on this wonderful forum since becoming a pool owner 2 years ago. Thank you. My pump died in the recent rains despite the GFCI breaker. Water in the electric section. The pump itself was dry under the cover and there was water only on opening the electric section...
Hi All, Just wanted to share with you the level of support I received from Hayward Canada. I'm not a shill for the Hayward - just a consumer that over the years has had mixed experiences with a variety of manufacturers, and I thought I'd share a positive one. I opened my pool this past weekend...
