LONG story short, I've had to pull up some of the concrete decking to repair/replace plumbing issues.
I figured since I had it torn up, I'd go ahead and add 3 deck jets on their own separate control valves.
I went ahead and added the new plumbing and it works fine.
My issue is that I ordered and received 4 (I wanted an extra one just in case) deck jet assemblies off of Amazon. They are plastic housings and plastic jet heads.
After installing all 3, I noticed that all of them drip slightly at the ball joint of the head.
I have some brass heads and tried them instead. Same thing happens, in the same area.
I used teflon tape, so it's not leaking on the threaded portion, just adding the ball joint of the head.
Any ideas, suggestions, recommendations??
Thanks!
Jim
Thanks!
Jim
