draining the pool?
Also, until your kit comes add 5ppm worth of liquid chlorine each day until you get some good data to go on.
The CYA of 120, was this using the extended test? Dilute pool water 1:1 with tap water. Use that mix as your sample. Double the result.
Reactions: Mdragger88
