My pool was built 4 years ago. It was filled then and hasn't been completely drained since. It's an in-ground, (from my estimate) 11000 gallons, pebble finish, with a SWG and a DE filter. Up until recently I was just using the home depot test kit and adding acid when necessary to decrease pH and adding salt when the SWG reported a low amount. Now I have a K-2006 test kit and a subscription to the pool math app, and I have been properly checking everything and trying to do things right.
My current levels are:
5.8ppm FC
pH of 7.8
80ppm TA
70ppm CYA
Calcium Hardness of 1100ppm
My calcium hardness is through the roof. After some reading of TFP and the K-2006 manual I did the various versions of the CH test to make sure I was getting an accurate reading. My sample is turning purple and then blue, but it never turns back to pink so I think that's correct.
So, now I'm thinking I need to drain and refill. That might be slightly overkill just for the hardness, but we also had very bad wildfires here in the Los Angeles area (as you may have seen on the news) and that left a LOT of ash in my pool. Now I worried about heavy metals and other toxic junk that may have come from the ash that I don't want to be swimming in.
My question is, what should I do while the pool is drained? Should I have it acid washed? I've heard lots of mixed things about this and I'm leaning toward not doing it. If not acid wash should I clean it some other way? Is there anything I should inspect while the pool is drained?
When I do refill I'm going to use part city water and part water from my home softener. I tested the water from the city using the same CH test and I got 320ppm, so with about 2000 gallons from my softener I'm thinking to dropping that down to about 260ppm which will give plenty of room for the level to rise with evaporation.
Thanks in advance.
TL;DR
4 year old pool, 11000 gallons, pebble finish, SWG
Hasn't been drained since it was built
Calcium hardness is very high, 1100ppm
Lots of ash from wild fires
Thinking about draining and refilling
Should I drain and refill?
If so, what should I do while the pool is empty?
5.8ppm FC
pH of 7.8
80ppm TA
70ppm CYA
Thanks in advance.
TL;DR
