Dolphin Nautilus cord shroud pulled out, help fix
John85
Jun 4, 2016
65
Saint Louis, MO
Hayward Aqua Rite (T-15)
The shroud of the electronic wires coming out of the swivel (toward the control box) of my vacuum came out last time I removed it from the pool, exposing the insulated electronic wires inside. I was able to push it right back down so it looked right but I'm concerned it could lead to a live wire in the pool. Is there a right way to approach this repair or is it probably fine? Happy to add a picture if helpful. I'd like to avoid buying a new cable if possible ($180 plus time to put it on).
Thanks!
John,
The robot runs off of 24 Volts DC, so there is no 'live' wire from the safety point of view.
I'd just stick it back together.
A pic would be great as I am having a hard time visualizing the problem.
Jim R.
Here are two photos for context. @Jimrahbe Do these help clear it up?
I'm having a similar issue. I am planning to cut the wire then figure out how to get the swivel connector out of that section.
For info, that connector does unscrew into two separate halves.
In the meantime I have ordered a new cable, $199 but on back order..
The swivel separates at the highlighted section.
Reactions: Jimrahbe
Just to be clear.. I have not done this..
I'd open the swivel and see if I could force the card back in, assuming it was still electricity connected.
See post # 5 for where it comes apart..
Jim R.
