Re: Doheny's Discovery, S200, Active20, Triton owners club
Here are some of my impressions of the Dolphin S200 after having it for a couple weeks.
* Refurb unit was a good deal. Looked just about new. It had one problem though. After the first run, it wouldn't work right. It would stop after 5 or 10 minutes. I worried maybe the refurbishing hadn't fixed its problems. I decided to take the cover off the impeller just to check that it wasn't clogged with debris. It turns out whoever last put it together in the factory didn't snap the vectoring jet nozzle into its clips properly and it was loose and blocking the water flow. Once I attached it correctly I had no more problems.
* 2 Hours run time isn't enough to fully cover my pool. It is irregular shaped and all curves. Maybe its program doesn't handle that well? After a 2 hour run I still see dirt and debris in spots it didn't get to. I sometimes need to run it twice if there is a lot of stuff on the bottom, and even then it can leave some. Running it daily seems to be the best plan. Over the course of a week it gets everything clean except for one big leaf that it never got. I finally gave up and got out my net
* I love the filter basket. It picks up fine sand and is easy to clean out. Much nicer than the velcro bags on my old Polaris sweep.
* I haven't had any problems with cord tangling yet.
* The tile line scrubbing doesn't work as well in my pool as it does in the youtube videos. Maybe because my tile line is curved? Right now it isn't a problem. We'll see how it does in the next month when the pine tree pollen starts leaving a florescent yellow line on the tile. That will leave a visible indicator of places on the tile line it has missed so I can really assess how well it is doing.
* It is quiet! Especially compared to the failing booster pump from my polaris. It also doesn't spray water all over the place from its tail.
* Low electricity usage compared to to the Polaris pump. I was shocked at how low my electricity usage was for April with the pool open half the month. This and the variable speed pump I installed last year are much more efficient.
All things considered, I am satisfied with its performance. With regular use, it is keeping the pool clean and saving me work.
